Do you fly above 35C/95F outside?
Do you fly above 35C/95F outside? I think manual says 45.5C/114F maximum
  • Yes
    Votes: 12 85.7%
  • No
    Votes: 2 14.3%
  • Total voters
    14
Yeah. I've flown in 95 degrees F and 85% humidity. Bird and iPhone had no problem.
I'm glad it is not black, I bet the Solo gets very hot.
DJI did good adding fans, with all the electronics on a single board makes me worry some. From pictures it seems to have some vents too.
Reactions: dalebb and Jbundy63
Definitely agree that the black Solo's would have to get hotter. DJI Phantom being white is a plus and is vented for better cooling.
37 degrees [emoji16][emoji16][emoji16] Burrrrrrrrr!!!!! You must be up north? LOL
FYI that my manual at least says a max of 104F/40C. That temp is not unusual in my area, but I don't intend to find out what happens if I fly when it's that hot.
I already switched from an iPad Mini 2 to an Air 2 when the Mini started to overheat and lag in the high 90's. The Air 2 is smooth as can be, but even so I think 100F/38C will be my upper limit.
a bright shiny day is nice, but when it gets above 85 degrees F, time me to go for the shade and a lemonade. :) 20C is a nice summer:)
I flew in 110F Palm Springs weather two weeks ago, the drone did ok but I tried to keep the flights short (7 min at a time). I was mostly worried about the batteries overheating and giving out. You can see that info in the app and I compared it to the battery rated temp. I was also sure to let it cool down before charging the batteries.
Also I'm not sure if this is related, but the FPV streaming stuff cut out a lot. And yeah my phone overheating too
shimuafeni fredrik
