mcmax20 said:
There is no collision avoidance programmed into the phantom 2 or ground station, or topographical adjustments for that matter. If you tell it to fly into the ground it will. I find the best flights happen after a few trial and error GS experiences. If that's the shot you're looking for then give it a mission you think will work, watch the video afterwards and then make adjustments to your mission. Rinse and repeat.
I' recommend to get an accurate estimation for heights of objects to fly the area on your own and make note of elevation changes (assuming you have iOSD), then you can use those numbers and waypoints for your ground station mission.
Just make sure you have FPV so you can abort mission if you see it flying too close to that hill!
If I'm interpreting you correctly, it will fly at the altitude you set relative to the point it launched? Here's my scenario, I'm on a cliff about 500 ft above sea level. I want to send my Phantom to another cliff. It should travel to the other point at the same altitude, correct?
I actually have over 30 GS flights and I do all my filming at sea level, but I'm headed up to the mountains.
