DNG Files
Discussion in 'Photos and Video' started by Big_A, Oct 6, 2015.
Tags:
  1. Big_A
    How to I get DNG files from the P3A to Photoshop CS3 in Wndows. I have tried DJI_DNG_Cleaner, and Adobe DNg Converter. That one just produces a JPEG which I could have taken in the first place. I want edit non lossy raw files in bitmap form, just like I do with my Nikon NEF files.
  2. bbfpv
    Long Island, NY
  3. Big_A
    Thanks, but for CS6 at Amazon for £1299 there has got to be a cheaper way to get one type of file unwrapped.
  4. TonG
    The Netherlands
    You can try Lightroom. Its a lot cheaper.
  5. Cerone
    San Diego, CA
    You'll need a newer version of Camera Raw, which should be free.
  6. TonG
    The Netherlands
    As far as I know newer versions of camera raw will not work with CS3. You need at least CS5/6
  7. ATPhoto
    Ballarat, Australia
    Why don't you get Photoshop CC @ $10 a month....its well worth it
  8. Big_A
    I've Got It,
    ADOBE DIGITAL NEGATIVE CONVERTER Version 9.2.0.486 It's Free
    Make shure Preferences is set to your version of Photoshop
    To change compatibility preferences, follow these steps:
    1. In the Preferences section of the DNG Converter dialog, click Change Preferences.
    2. Now, choose one of the following options:
      Camera Raw 2.4 and later: The DNG file will be readable by Camera Raw 2.4 (Photoshop CS) and later, and Lightroom 1.0 and later
      Camera Raw 4.1 and later: The DNG file will be readable by Camera Raw 4.1 (Photoshop CS3) and later, and Lightroom 1.1 and later. The DNG file will often be readable by earlier versions, depending on the camera model.
      Camera Raw 4.6 and later: The DNG file will be readable by Camera Raw 4.6 (Photoshop CS3) and later, and Lightroom 2.1 and later. The DNG file will often be readable by earlier versions, depending on the camera model.
      Camera Raw 5.4 and later: The DNG file will be readable by Camera Raw 5.4 (Photoshop CS4) and later, and Lightroom 2.4 and later. The DNG file will often be readable by earlier versions, depending on the camera model.
      Camera Raw 6.6 and later: The DNG file will be readable by Camera Raw 6.6 (Photoshop CS5) and later, and Lightroom 3.6 and later. The DNG file will often be readable by earlier versions, depending on the camera model.
      Camera Raw 7.1 and later: The DNG file will be readable by Camera Raw 7.1 (Photoshop CS6) and later, and Lightroom 4.1 and later. The DNG file will often be readable by earlier versions, depending on the camera model.
      Custom:
      • Backward Version: DNG 1.1, DNG 1.3, or DNG 1.4 (default 1.4)
      • Linear (demosaiced): The image data is stored in an interpolated (“demosaiced”) format. This option is useful if a camera’s particular mosaic pattern is not supported by a DNG reader. The default mosaic format maximizes the extent of data preserved. Mosaic image data can be converted to linear data, but the reverse is not possible.
      • Uncompressed: No compression is applied to the raw image data.
    1. Click OK.
    I have always used Digital Negs with my Nikon stuff they are called NEF Files there, if anyone wants convincing of the advavantages of DNG read this.
    http://wwwimages.adobe.com/content/dam/Adobe/en/products/photoshop/pdfs/linear_gamma.pdf
    zitrojj and BigAl07 like this.
  9. SS220
    Old Thread, I know, but thanks! Just picked up a P3S and was struggling with using the dng files in ps3. Preference thing worked like a charm!
  10. zitrojj
    Queens NYC
    Thanks a million!! I still have cs3. Yes I am being a cheapo. :) your information helped a lot.
  11. ELHEAPO
    Blighty
    HOW MUCH!!should of got lightroom dude!
Similar Threads - DNG Files Forum Date
Dark corners in .DNG files? Phantom 4 Pro Help Apr 24, 2017
Cannot open dng files on MBP mac os sierra. Phantom 4 Pro Discussion Feb 22, 2017
DNG files very saturated, noisy and full of contrast General Discussion Jan 24, 2017
Raw/DNG files for P4 Pro Phantom 4 Pro Discussion Dec 11, 2016
Purple lines on DNG raw files Phantom 4 Help Nov 13, 2016
