the individual left out the configuration of the ESC's to the NAZA. Can and one help me with this completion of the wiring . He said I need a coax 8 to connect 8 ESC's. What is a coax 8?
Check out the link below on what I'm trying to do from this individual from rcgroup forum and the message.
Yes, with a coax 8 you use 8 ESCs all connected to the output end of the Naza, and you can choose in Naza Assistant the correct motor mixer (x8) so it knows which motors to fire.
You do need to install the props "upside down" on the bottom motors and reverse the motor direction because they will be spinning reversed when inverted.
