- Joined
- Mar 3, 2013
- Messages
- 6
- Reaction score
- 0
Hi everyone,have been flying the Phantom for 3 months with dozens of tests on props,gimbals,lighting add ons ect,First Carbon Props are better with cams on board but descent is much faster,the stock props are more flexable and act like a parachute if you have to get down real quick,also the carbon props are twice the grams.2nd gimbals,so far everything out there on the market is heavy even if the vender claims its for the dji Phantom,please keep that in mind since any extra weight cuts your flight time,also the servos work of your main battery.FPV and OSD,get the smallest setup you can find,25 to 100MW is a good choice since the phantom is ony good for 300meters(985Feet)at 5.8mhz,anything else or high power requires a ham license and is heavy because of external batteries,this quad is really not set up for a lot of weight.3rd lighting,if you like to fly at night Leds are great,they have super bright LEDS made for the configuration for the Phantom in all colors and multi colored with strobe,they also put out a super bright LED for night photography and is 5/8 of inch in circumference works right off your flight battery with little drain,small switches can be installed in line for daytime flying.These add on lights really get response at night,also help in navigation,the stock leds work fine if your quad is close to you and above your position, but 200ft up and away from you is a different story,its easy to lose reference at night,thats when HOME LOCK comes into play.4th battery upgrade,stock is 2200mah 20c,okay for an unloaded Phantom,i use 2200mah 30c,big difference in flight time and it fits into the compartment,from ROC 66amps cont:to the end,the other is a 2700mah 25c but a little tight.Last the Most Important to everybody that owns one of these great toys.Recalibrate after each flight in your assistant software.I found out after each flight this quad needed calibration,whether it flew on a calm day or a windy situation,and all were smooth landings since I have round foam on the landing skids.I hope this helps out a lot of us,as I`ll do more testing I will post more infne more comment,after you have acquired the GPS and have flown your phantom ,I would recommend doing this over everytime you fly by repeating the 360 degree processs.even more so if you have recalibrated your unit.
