DJI Phantom 3 Gimbal Problem
Discussion in 'Pro/Adv Discussion' started by mick74, Aug 16, 2016.
  1. mick74
    I crashed my P3P from about 20 ft up (Hit the corner of a building) It scuffed up the blades, (replaced them) gaped the shell in one spot, (fixed it) and it gaped the gimbal arm a little. The gimbal saver i have on it kept it from coming completely off and kept the ribbon from breaking. I pressed it back together and the camera works fine. The only problem I'm having is the gimbal won't stay calibrated. When I start it up the camera is at a severe angle, So I go into (Auto Calibrate Gimbal) and it levels out and then i tweaked it with (Adjust gimbal roll). After that I do a (IMU Calibration), and everything is working great. Took it out, flew it around, videoed so stuff, then landed it. The next time I start it up the same thing happens with the camera having a severe tilt. It won't hold the gimbal calibration. :(
  2. MPPilot
    Swarthmore, Pennsylvania, United States
    I recently went through a similar crash. At first I thought the only thing that ended up bad was the rotors. After a couple of days I noticed that the gimbal arm had a slight tilt to it when "at attention." The arm had been bent a little, just enough to throw off the camera but everything else seemed to work fine. Check your gimbal yaw are. It should be nice and straight when powered up. If it is not it is a rather easy and inexpensive fix.
  3. mick74
    Not sure what you mean by Gimbal yaw?
  4. MPPilot
    It is the thin arm that hangs down behind the camera.
  5. mick74
    It's not bent, But thanks for the heads up. :)
  6. HWCM
    There is a magnet around that shaft that tells the arm position. I bet it has come loose or broken. It is a magnetic ring with polarities on opposite sides? something odd like that.
  7. HWCM
  8. mick74
    This fixed it! :)
    HWCM likes this.
Similar Threads - DJI Phantom Gimbal Forum Date
dji phantom 3 4k gimbal parts Phantom 4K Jan 6, 2018
DJI phantom 4 pro gimbal General Discussion Dec 25, 2017
Advanced Will a frayed gimbal cable affect the update process on the Dji Phantom 3 Pro/Advanced? Phantom 3 Help Dec 14, 2017
DJI Phantom 2; start up trouble, gimbal? Phantom 2 Vision + Discussion Dec 12, 2017
DJI Phantom 4 - flicker during move or vertical gimball motion ? Phantom 4 Discussion Dec 10, 2017
