Dji phantom 2 vision +
Discussion in 'Phantom 2 Vision + Help' started by Kurtis, Dec 29, 2015.
  1. Kurtis
    my phantom 2 vision + turns on normal then flashes yellow and the bind button is flashing red its seems as its a transmitter problem but when I turn the transmitter on the
    red flashing light goes off as if it was binded but still continues flashing yellow please help.
  2. Mark The Droner
    Turn on the transmitter first.
    Turn on the Phantom's battery within the craft next.
    Report back.
  3. Kurtis
    Hi tried that but still yellow flashing light I have tried plugging in the controller to the computer but it won't connect but if I try connect the drone it will connect straight away and yes I have used the rc assistant to try connect the controller.
  4. Mark The Droner
    I would look in your manual and go through the procedure step-by-step for linking the transmitter with the craft.
  5. hunch
    keep controller off,
    turn on the bird,
    press the bind button, it will flash amber,
    turn the controller on.
  6. Kurtis
    Hi already tried all that the amber light comes on then it seems to bind but still flashing yellow.
  7. Mark The Droner
    Your comment doesn't make sense. By definition, the binding is successful when the binding lamp goes off, so how can it "seem to bind" and still flash yellow?
    From your description, your aircraft seems NOT to bind.
  8. Kurtis
    I press the bind button it goes Amber I turn the controller on then the Amber light goes off but still flashes yellow and the controller won't connect to the assistant so I think it's the controller that's at fault.
Similar Threads - Dji phantom vision Forum Date
dji phantom 2 vision plus crash Landing on 12000ft Phantom 2 Vision + Help Aug 4, 2017
Repair DJI Phantom 2 Vision NAZA Phantom 2 Help Jul 16, 2017
Phantom 2V - DJI Vision app issues Phantom 2 Vision Help Jul 9, 2017
Rewiring DJI Phantom 2 Vision to use WiFi without Camera Phantom 2 Vision Mods Jul 3, 2017
Just bought dji Phantom 2 Vision Phantom 2 Vision + Help Jul 1, 2017
