salve potete aiutarmi a risolvere questo problema??? se avete qualche schema che mi possa aiutare a fare qualche ponte!
grazie in anticipo
if you buy a new power supply board solve the problem? It costs about € 60That is a two sided main board and from the damage you have you would be better off buying a new board.
YesThat is correct but it's called a central circuit board.
Thanks broAll the P2 line of quads use the same board. So it is correct.
