Dji Phantom 2 - Run motors without props?
Discussion in 'General Discussion' started by browen81, Feb 22, 2015.
  1. browen81
    Did some research and couldn't find an answer.
    Is it bad, will it damage the motors or any other components to run the motors without the props installed? What about different speeds, idle, full speed?
    The reason I ask is I want to discharge my batteries to the optimal storage of 50%, and I was thinking that leaving the motors on without the props will achieve this faster.
  2. SteveMann
    Westford, MA
    Probably none. I did this from time to time while building a hex with larger motors and ESCs.
  3. Meta4
    Meta4 Moderator
    Staff Member
    Nothing wrong with running for short periods for testing etc without props.
    Might be overheating issues if for longer periods like you're sugggesting
    If you have up to date battery firmware, that will auto discharge to 50% if batteries are unused for 10 days anyway
  4. browen81
    That leads me to another question.
    I know the smart batteries will self discharge over time; But i read somewhere that if you ever press the button on the battery to just light up the lights it will reset the discharging timer, and bring it back to day 1. Is this true?
    Meaning you could always reset the timer, and the batteries will never discharge, therefore resulting in damage to the battery.
  5. mendezl
    Mandeville (New Orleans) Louisiana, USA
    I read somewhere that you can turn the battery on and leave it on for a few hours untill it discharges to about 50% then turn it off. This is faster than waiting the 10 days to auto discharge. I also remember something about storing them in refrigerator for storage long term. I'll see if I can find links.
  6. tcope
    Salt Lake City, UT
    I saw DKI post that in their forum.
  7. discv
    London, UK
    One possible down side- with the props not fitted the motor could rattle/chatter because the rotor will not be properly seated on its thrust face.
  8. Fplvert
    Southern Idaho USA
    :D
    The motors run fine without props. The wifi module can overheat however. It's best just to hover with props for awhile to drain battery for storage.
  9. Monte55
    Raymore Missouri
    In my opinion, running motors to run down batteries is like running a car engine to drain the tank. It all equates to wear. I would think someone would have a product to discharge these batteries in a proper manner without flying or running your motors. Just seems dumb to me.
  10. CityZen
    NYC
  11. Mori55
    NJ-USA
    I've heard that if you run the motors without props at full throttle you can damage the bearings. I did it with my old phantom and the motors made some weird noise. Didn't do it again. If I want to drain the batteries I'll fly it around the yard or just wait for them to do their self discharge that's seems to work fine.
  12. Fplvert
    Southern Idaho USA
    Electric motors run specific RPMs. They will not over-rev like a gas motor with no load or limiter.
    MHL
Similar Threads - Dji Phantom Run Forum Date
DJI is replacing my runaway Phantom 3 Advanced Pro/Adv Discussion Apr 2, 2017
Engelberg-Lauterbrunnen DJI Phantom 3 Pro 4K HD Photos and Video Feb 13, 2016
DJI Phantom 2 Battery Unlocking To Run 4S Phantom 2 Vision + Discussion May 31, 2015
Limefuel L54P running on the DJI Phantom 2 Vision+ Phantom 2 Vision + Discussion Feb 3, 2015
DJI Phantom 4 GOLD Edition... Off Topic Friday at 4:59 PM
