DJI Phantom 2 is dead, it seems.
Discussion in 'Phantom 2 Discussion' started by rockoswald, May 30, 2014.
  1. rockoswald
    I can't get my DJI Phantom 2 to turn on at all.
    I've had it for about six months and it's previously worked fine. I have a ZenMuse Gimbal 2 installed, and it used to work fine also.
    I took it out to fly a few days ago and the gimbal wouldn't turn on at all. Now, the entire copter won't turn on.
    I've verified that the batteries are fully charged. When I insert the battery and turn it on, the copter just sits there. Since it won't turn on, the software won't recognize it.
    How do I do a hard reset? Or any other tips to resuscitate my dead copter?
    With appreciation,
    Chris
  2. xgeek
    London, UK, Declination -1.2
    When you turn the battery on do you see the 4 green LEDs on the battery count up like normal?
  3. rockoswald
    Yes, I do. No noise from the copter at all though.
    In fact, I have two batteries, same behavior with both.
    Thanks for engaging with my issue..
    Chris
  4. tom3holer
    Cape Cod, Ma.
    Chris,
    You might check the contact pins both the main and the two little ones to see if they look in tact.
    Tom
  5. sar104
    Los Alamos, NM.
    No lights, nothing? Does the battery stay on, or switch itself off?
  6. rockoswald
    No lights on the copter, nothing. Battery simply seems to turn itself off. In fact, the battery acts the same as it does when turned on outside of the copter. It flashes, the LED's climb, and then it blinks and turns itself off.
  7. N017RW
    Palm Beach Co.- FL
    Do you push the power button twice and hold the second time until the a/c powers up?
    You did say you have flown before but thought I'd ask anyways.
  8. rockoswald
    Yes, I'm familiar with how to power up. That's what makes this so confusing. And I flew just days ago! And it wasn't an eventful flight. Everything worked normally except the gimbal.
  9. Sanababit
    Open up your phantom and check all soldered wires, especially the power cables
    Sana
Similar Threads - DJI Phantom dead Forum Date
How to Reflash dead dji phantom Phantom 2 Vision + Help Jul 25, 2017
DJI Phantom 4 GOLD Edition... Off Topic Friday at 4:59 PM
Dji Phantom 4 Video Choppy on Playback but not in Live View. Phantom 4 Pro Help Wednesday at 7:18 PM
DJI Phantom 4 Remote Controller Classifieds Tuesday at 9:15 AM
DJI GO APP for Phantom 3 Professional Pro/Adv Discussion Aug 14, 2017
