DJI Phantom 1.1.2 Receiver Board Binding Not Sticking
Firstly, hi!, i'm a NOOB - and have just built my first quad.
I lost my Phantom a while back - so have built my own quad and am using the Phantom transmitter until i can upgrade to a dx8.
Just finished the quad builld (Reptile 500 frame with Naza V2+Gps, simonK escs, outrunner 1000kv motors)
I purchased a replacement stock receiver board (1.1.2 - the dual antenna version - which is what i had in my sunken phantom) and have put it all together.
The receiver board has 2 sets of servo pins - unlabeled - and by trial and error I've worked out which way and which sets of pins to use
I've wired it all up - and all seams to the working - but i'm having an issue with the transmitter, having to rebind after each power on.
Not sure if i'm supposed to have the other sets of pins wired somewhere? Or if there's something obvious i'm not doing correctly.
When i power up the quad, the receiver is flashing green (transmitter on) - I hold the bind button for 2 seconds, it flashes red then binds with solid green - and then all is fine. (i can fire up motors etc)
If i power off the quad, and plug it back in - i need to rebind it again.
I've tried updating the firmware on the transmitter, and calibrating but same story.
Hoping someone can shed some light - otherwise i'll invest in a new receiver - its just that i'm based in Cambodia - so will take weeks to arrive
On another note - any recommendations for a receiver that will work with the stock transmitter (1.1.2 with the tilt knob on the back)
Thanks in advance!
Just been all through this myself. Are you using a Naza v2 which is not from a Phantom?
If so- the Phantom Rx will not bind correctly. I think it has something to do with the firmware. You will notice on DJI support that the firmware for the Phantom, is marked as for the Phantom only.
You could be adventurous and load the phantom version of firmware, but I don't think that's a good idea.
Best bet is a new [non Phantom] Rx. If you are using a stock Tx any Futaba compatable Rx will do.
Edit; thought I should qualify the above post. The incompatibility was discovered by Helipal support. I question this and contacted DJI. They replied :eek: - and confirmed that a Phantom Rx board will only work in a phantom-or at least with a phantom Naza.
I got hold of a DT7 combo- and all is good
Thanks in advance!
Which set did you use? I am having the same issue. Front pair or back pair?
While a NOOB myself I spent lots of frustration binding to the wifi extender. Got told by a fellow pilot to bind to camera. Frustration gone, stupid feeling remained till my first successful flight. :)
mactechnic
