  1. efexor
    just received my ph4 charged everything
    CAlibrated gimbal 3-4 times so the Screaming
    Stops...nothing !
    Calibrated IMU
    Calibrated compass
    Nothing ! As soon as I touch the side of the gimbal
    The screaming stops,when I let go it starts again..
    It screams horizontal,and as soon as I move
    The gimbal dial for the camera to go downwards it stops.
    On the bottom of the gimbal is it normal for it to be hot?
    any help on this would appreciate ..
    #1 efexor, Apr 12, 2016
  2. Sinisalo
    It may be nothing, my gimbal does not do it as loud as yours but mine makes the same sound. Where did you buy from?
  3. Sim597
    Wow, can u replace it? It sounds like an attenuation frequency issue, meaning, sounds like it's vibrating at a speed that then makes that high pitched sound, something through the magnesium core maybe? If it could be returned, I'd kinda slap it it hit it, not too hard, just hard enough to see if it's due to a variance in tolerances, like a spacing issue.
  4. efexor
    Sim597 Cacaxaxaxaxaxaxaxacax
    Slap it I'll think about it..
    I brought it from a shop in Greece
    He is a retailer,I'm waiting for his reply from dji
  5. Sim597
    Lol, you know, tap it, hard tap! See if it's just being cranky and needs to be tuned up! Lol of course I'm sure you doubt as I do it's a solid fix, but stranger things have happened
  6. efexor
    Sim597 just did it ,stopped for some time then started again screaming.....I'm thinking hitting it with a hammer,,it's also hot is it natural for the gimbal to be hot?
  7. chuirasmi
    I had experienced exact issue so I exchanged at Apple this one seems fine
  8. never88winter
    My p4 doest do that at all!
    There is a prblem!
    Take it back!
  9. never88winter
    Apple is great!
    Just call them and shouldnt be a prblm
    They will send you a return fedex thingy, paste it on the box
    Tell them you want an exchange
    And once you ship it, then it gets scanned and then fedex sends a ping to apple server,
    You get it ordered automaticaly!
  10. efexor
    After speaking live chat here in Europe and usa with the technical department and my dealer the screws had to be tightened on the gimbal and BANG that was it no more screaming thanks for your reply and now having fun with my phantom 4...
    GadgetGuy likes this.
  11. BriRi
    Can you show a picture of which screws you tightened? Thanks in advance
  12. aaronrivera
    I have exact problem but only wen i tilt my aircraft e.g wen i calibrate the bottom sensors
  13. Silverwingflinx
    gimbal motors should not be hot they can burn out that whiiiinnnniinnggg noise is from gimbal over load.
  14. chris digata
    Hold it by hand when powered but rotors not started, twist it flip it like its flying hard.. work it.. it should wear in and should stop after its been done a few times..
    if not then you know its a problem. but ive had a few like this and all fine now
  15. efexor
    [​IMG][​IMG][​IMG][​IMG]
  16. efexor
    BriRi
    Tighten all the screws that's what dji told me to do and yes my issue is over!
    Silverwingflinx on live chat with dji
    They said its normal for the gimbal
    To be hot..
    Dji emailed my dealer here in Greece that if I wanted a replacement and I said for the time being I have no issues and I don't want a replacement..
    I wasn't expecting a fast response from dji Germany for there support and my dealer here in Greece
    Multicopter mr Xristos
    And I'm amazed after all this..
    I'm happy now flying my phantom 4
    Thanks to all of you for your replies
    and it's good to have other people
    that understand!
    #16 efexor, Apr 18, 2016
    Sim597 and GadgetGuy like this.
  17. efexor
    aaronrivera I believe it will stop after tightening post and tell me how is your gimbal?
  18. PROJEFFREY11
    So by tightening the gimbal screws it stopped all the noise from the gimbal? Can you maybe post a video of the difference?
  19. efexor
    PROJEFFREY11
    I will upload a video with my gimbal clear of noiz actually 3 screws needed a bit of tightening..
    and that was it.if Chris digata has results as he posted further up from his experience then there you have it as well from him also.
    DJI USA and DJI EUROPE said the same thing tighten the screws and the problem will be solved and that's what happened to me..
  20. efexor
    Here you go no screaming .
Similar Threads - Dji ph4 Gimbal Forum Date
How can I get my picture from the DJI app (lost my SD Card) Standard/4k Discussion Today at 1:04 AM
Update for DJI GO App (P3) Standard/4k Discussion Today at 1:01 AM
DJI GO app Control (Go, Litchi, etc..) Yesterday at 11:15 PM
DJI Assitant 2- Reboot the aircraft Phantom 4 Discussion Yesterday at 7:45 PM
DJI Pro app will not connect P3P Pro/Adv Discussion Yesterday at 6:40 PM
