DJI p3 gimbal noise
Hi Alan, what can i use to tighten the set screw ? I’m also trying to take the top part of the shell off, I’ve managed to get the 4 motor mount screws off with Allen key, but struggling with the other size screws? What do i need for the other 3 on the arm ?
Josh
Did you find any other problems other than the sound? It is probably nothing inside the shell. Its the gimbal. You will need a T6 and a T20. The one on the gimbal uses a T6 i think. Or a T8. You can remove the gimbal to work on it alone by removing the stoppers, pushing up the plastic discs and then un-clipping the two cables attaching it to the ac.
wkflysaphan4
