Can you explain more on how to downgrade p3p? Gone through your tread, can't found any video linksome guy on the rcgroups forum said he got it down to 1.3.2 from 1.6 he used the sploodge trick. video link is in my downgrade remote success thread.
Just want to be clear. Is it really 1.4.3 before 1.5? All I can found is 1.4.11st page of my thread.
you will likely need to go from 1.6 to 1.5 do the sploodge trick, then try 1.4.3, sploodge trick again, then 1.3.2
or if that didn't work, 1.6 to 1.5, sploodge trick, 1.5 again then 1.4.3, sploodge trick again, 1.4.3 again, then 1.3.2
he said he couldn't get below 1.3.2, and neither could I...
For some reason I can't get this to work. I can't even get the one embedded in the link above. I keep getting the following error page:*ALL* the old firmware is there if you manually edit the URL and change the version of the fw, ie:
http://dl.djicdn.com/downloads/phantom_3/Phantom_3_Professional_Firmware_v1.1.9__en.zip
this XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error><Code>NoSuchKey</Code><Message>The specified key does not exist.</Message><Key>downloads/phantom_3/Phantom_3_Professional_Firmware_v1.4.3__en.zip</Key><RequestId>05BCFEBBFE386D30</RequestId><HostId>WJEBIO8WWprsOor4a723cRgGlHexynvis1FwEUmm6nNO3On4oicqCWOuk0GEgRtEpKwbLR+Hrno=</HostId></Error>
I have posted links to all FW many times, but here is the latest post if you want to save them directly from DJI. Of course, DJI could pull them at any time so it best to download them if you want them.Excellent link. I was thinking about trying to find these files and "save" them locally for future use.
Thank you. Excellent post.I have posted them many tines, but here is the latest post if you want to save them. Of course, DJI could pull them at any time so it best to download them if you want them.
80 to 90% battery level takeoff is triggering outrage | Page 5 | DJI Phantom Forum
If there is enough interest I may be willing to post the firmwares for download on my site, I have back to 1.1 I believe. I might be missing one but i'm pretty sure I have them all, have not tried the sploodge trick yet on any of my birds. I find the issue is if the DJI GO app is updated and you are trying to use too low a firmware the video link will not show. It was only after updating aircraft firmware that the video came through. Anyone else have that?
Correct. You'll need the version of the Go app that corresponds to the FW available at that time.If there is enough interest I may be willing to post the firmwares for download on my site, I have back to 1.1 I believe. I might be missing one but i'm pretty sure I have them all, have not tried the sploodge trick yet on any of my birds. I find the issue is if the DJI GO app is updated and you are trying to use too low a firmware the video link will not show. It was only after updating aircraft firmware that the video came through. Anyone else have that?
oops 1.4.3 is the remote firmware, I meant 1.4.1Just want to be clear. Is it really 1.4.3 before 1.5? All I can found is 1.4.1
try the sploodge trick, and then go to 1.5 again, then try 1.4.1So far I've had no luck going from 1.5 to 1.4 with the sploodge method. Maybe I'm doing something wrong. On mine 1.6 was in. Then I rolled it back to 1.5. There are five flights on 1.5. 1.4 bin file went on sd. Started it with sploodge trick, nothing. I must be screwing something up with the process.
