DJI GO will not start after install Litchi
Antwerp
I use them together for some time now.
Wenn I try to start DJI Go I DO NOT get (android 6.0.1) 'the choice between DJI GO or Litchi USB4
choice anymore.
Even if I pushed DJI GO to start my Nexus 6P android 6.0.1 starts in LITCHI.
How can I force my USB connection to let me chose ?
Is it an Android known Error ?
I tried to change in setup 'USB error debug' , but No differnce
Anyone suggestions ?
tnx
Instead of DJI GO starts Litchi automacialy.
On my Nexus 10 android 5.1.1 it is working Normal
if I push DJI Go it start DJI GO but before staring I can chose between USB DJI GO or Litchi USB
OK... I have had this same problem. You need to clear the defaults in Android. I will do a screen shot video and show you how to fix it if my explanation is not good enough. This is a frustration I have with Android. It sets a default and then you have to manually remove it. But, here is what you must do:
1. Make sure you have both apps closed. You can do this in Android or you may have a Task Killer app. I use Zapper Task Killer
2. Open your application manager
3. Select Litchi
4. Select CLEAR DEFAULTS (if there are no defaults set, it will be (greyed out and you can't select it). This should fix it.
5. Do the same for any other flying apps you have (DJI Go, Vertical studio, Altizure, etc.)
With all apps closed, have your phone plugged in to the DJI remote controller. Turn on the controller. It should let you pick which app to use. It may set that app as default so you may have to do this process whenever you want to switch between apps. There may be a way to keep it from making a default but I am not sure how to do that.
I have to go have breakfast with my wife, now. I will check this thread in am hour or so and make a how-to video if you need me to.
Tnx for the info.........I will try it and let You know if it solves also my Problem on my Nexus 6P
Yes this is the Solution..................tnx
Maybe here are some Android specialist wo can give an continious solution for Android users so
that I ALWAYS get the indication
" Chose an APP for your USB apparatus'
DJI Go
Litchi
DJI Go
Litchi
I am glad it worked. I also hope for a REAL solution so we can choose each time.
Pretty simple, follow the instructions posted earlier to clear your defaults, and when you next plug in your device and it pops up to choose your app, make sure you don't choose the option to set it as default.
I do not get an option to "Set as Default". I wish I did. I have to go to the application manager and clear defaults from whatever flight program I last used in order to get a choice to use a different one. See below for what I get now that I have cleared defaults:
argues
