DJI Go ... must connect USB 'after' controller and aircraft
Discussion in 'Pro/Adv Discussion' started by Flyer91, Dec 8, 2015.
  1. Flyer91
    In the Sierras, 17 miles outside Yosemite N. P.
    I've noticed that with the latest updates to the controller, the Phantom P3P, and running the latest DJI Go, I need to connect my USB cable last, or I always get the "Disconnected" message.
    If I connect the USB cable 'after' starting up the controller and P3P and the app, or unplug the USB cable and reconnect it after it's all started, everything works fine.
    But if I start it all with the USB connected to my droid tablet, it's a "no go" and it always says Disconnected until I simply unplug, and then plug the USB cable back in.
    Is this normal?
    tcope likes this.
  2. tcope
    Salt Lake City, UT
    Yes, yes and yes. For me, I started doing this months ago. I've found that it's the only way to connect correctly 99% of the time. So... turn controller on without USB plugged in, turn P3 on and then plug in the USB. For me, I then select the app I want to use from the pop up choices and select Just Once.
    As mentioned, I've had issues with the connection sequence for awhile now, certainly before this last update. I now just do it this way every time and see almost no issues.
    Thanks for mentioning this, I've been meaning to bring it up.
    Flyer91 likes this.
  3. alirz
    Yup...same here and I'm still on the older Rd and p3p fw. But the way I'm using android. I'm curious does this behaviour occur on iOS also?
    Flyer91 likes this.
  4. Chevytwonova
    Not that i know of i plug in cable start controller then run the app lastly i turn on aircraft. Use my iphone 6s plus
    Flyer91 likes this.
  5. Oso
    Oso
    Western US
    Same as I do and also how it shows in the "How to Connect" in the app.
    Flyer91 likes this.
  6. Flyer91
    Thanks for the replies guys!
    Looks like it's a Droid thing then.
    It was causing me some serious undue worryation ... ;)
  7. MoOriginal
    I do it in any combination and on ios and never have a problem - only need to close the app and restart it to get connection again if it had been sitting in background
  8. Wacker2611
    Yes, initially that strict android start up sequence was an annoyance, but now it's just part of my start up routine. Muscle memory!
Similar Threads - DJI must connect Forum Date
FOUND DJI DRONE IN OKLA. MUST BE ABLE TO I.D. Lost and Found Aug 14, 2017
Why must DJI use 2.4 and. 5ghz only? General Discussion Dec 27, 2016
DJI and FedEx...a human must be home for delivery...grrrr General Discussion Aug 9, 2016
Is the DJI OSMO a must have? Osmo Discussion Nov 5, 2015
For Sale: DJI Phantom 2 - Open Box, NEW Condition, Must Go! Classifieds May 2, 2015
