Dji go iPad / phone question
North Wales
I previously posted this in general discussion but have had no replies so chancing my arm here.
I have a Phantom 3A with IPad Air running Dji Go and have had no issues whatsoever , I would like to try using my S7 edge with the new Android version as I believe the incorrect positioning issue is fixed.
My question is , can you connect the android version to the a/c without mucking up the ability to use the IPad? as I don't want to be mucking around switching between the two,or would I constantly have trouble? Also if you swap do you have to recalibrate anything or does that info stay with the bird?
The reason I would like to try my phone is I don't have cellular on the iPad and would like to try follow me function.
Thanks in advance
Tim
Yes, you can switch between Android and Apple devices. I do it often. Just make sure you double-check your settings in DJI GO since some of them are stored on the mobile device.
I have a Mini Ipad 4 and have been using it with my P4 since August 2016.
The latest Android release fixed the Home Point location error. It was released Feb 7th.
cgarner1
