I've downloaded the app (noted before P4 on the description) from the play store (android) and when given a choice to connect my drone P3 Std. it's not on the list only notes Inspire models, what's up with that ?
Thank you
Thank you
Did follow the steps in the Quick Start Guide to connect your mobile device to the Phantom's Wi-Fi network?
Thank you
This is not going to help until the OP connects DJI GO to the Phantom. At that point, DJI GO should auto select the correct aircraft.Swipe to the left. It's the next one over. Use the drop down box to select the P3S.
Maybe it's me but mine defaults to the first screen (Aspire) every time. It doesn't detect the PS3. I have to select every time I fly. Obviously, though maybe not to him, he needs to select the AC/RC in the wi-fi settings.This is not going to help until the OP connects DJI GO to the Phantom. At that point, DJI GO should auto select the correct aircraft.
It auto selects the Inspire even after DJI GO shows it's connected to your Phantom? That's odd.
What happens if you wait until your mobile device is connected to your Phantom before starting DJI GO?
