DJI GO accuracy and 2 random questions
Discussion in 'Pro/Adv Discussion' started by Charlie Waterhouse, Aug 3, 2016.
  1. Charlie Waterhouse
    Hey guys! I have a quick question as a new P3P owner. How accurate is the logbook in DJI GO? It seems like the flight time is longer than the app is showing. Where does it get the time data for the flight time? Also, on the main screen on the left side (the "all about me" spot, there is a definite error in that it says top altitude is 1.09FT - LOL. In the logs it shows my top altitude is 371ft.
    2 other random questions -
    1)How often do you replace props? Or is it just when they show damage...
    2) When looking straight up at the bird when it is high up I sort of get dizzy Is this something that will pass in time? I am fine unless it is right overhead, so I just use FPV then.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You only need to replace them if they are damaged. Check them carefully for signs of damage before each flight.
  3. jonebk12
    The DJI Go flight viewer/log can be quite inaccurate for some reason. I've had it show me going 50+ mph on flights when I was in P mode the whole time without much wind.
    Sent from my Nexus 5X using PhantomPilots mobile app
  4. Digdat0
    Oregon, USA
    Are you on iOS or android? I found the latest android version of Dji go to be very buggy In the flight log section. I run 2.8.1 and have no issues.
  5. Charlie Waterhouse
    I am running android, but plan on buying an iPad mini soon to run it. Is 2.8.1 the app release #?
Similar Threads - DJI accuracy random Forum Date
Installing DJI A2 Flight control on Phantom 2 - GPS accuracy Phantom 2 Discussion Jun 4, 2014
Map will not display or load in DJI app Phantom 4 Pro Help Yesterday at 9:47 PM
Dji Phantom 4 Video Choppy on Playback but not in Live View. Phantom 4 Pro Help Yesterday at 7:18 PM
Map issue on DJI4 Phantom 4 Help Yesterday at 3:28 PM
2 useless P3P after firmware. Thanks DJI Pro/Adv Discussion Tuesday at 11:22 PM
