- Joined
- Jul 23, 2017
- Messages
- 24
- Reaction score
- 3
- Age
- 59
It looks like your Phantom went to the beach.
Sorry for butting in, but if the airport was an issue, would you expect to see warnings in the flight data to reflect that? At 20 odd minutes, which is heading towards the normal battery life for a P4, the last entry was O% with a reasonable amount of voltage remaining. Unless it ended up in the brine and that was that.It looks like your Phantom went to the beach.
The last data is from nearly two miles to the east.
There's a 21 minute gap in the record and when you got connection again, it was near the corner of North Ocean Dr and Sherman St, on or close to Villas of Positano.
ps .. it's not a good idea to be flying so close to the airport.
I just noticed the airport because I flew in and landed there a month agoSorry for butting in, but if the airport was an issue, would you expect to see warnings in the flight data to reflect that? At 20 odd minutes, which is heading towards the normal battery life for a P4, the last entry was O% with a reasonable amount of voltage remaining. Unless it ended up in the brine and that was that.
Curious to see the OP's original mission and compare it to this particular flight.
Oh, that line seems to nail it, that has to be the awning
Also, it looks like the roof is accessible, flat and maybe a walkway, around the big awning.It could be. The raw data also indicate that it did not land of a level surface - it has significant pitch and roll values after landing.
We also flew my son's drone over the building and around but didn't see the drone
