DJI charging Hub not charging simultaneously
Discussion in 'Pro/Adv Discussion' started by evezina, Sep 15, 2015.
  1. evezina
    Hi all,
    I just received my 4 battery charging hub directly from DJI.
    I have 3 batteries and they are all low and on the hub right now.
    I thought that the point of having a hub was to have all the batteries charge at the same time (same time for me) but seems that it is only charging one at a time... I could have done that myself by changing the battery manually...
    Let me know please if I am doing something wrong.
  2. suck it up
    Nope your not doing anything wrong. That is how they work.
    Should have gotten a different one. I'll find a link for you.
    MarcG likes this.
  3. Dronason
    Switzerland
    No, it check the battery for a few seconds and then start charging the most charged first and the less charged last.
    As you connect your own charger, the capacity to charge more battery in parallel has not been improved.
    The main advantage is that you put your 4 batteries on it and after maximum 4 hours its done without having to check if a battery is finished and put the next one and so and so...
    #3 Dronason, Sep 15, 2015
  4. evezina
    Thanks! Good point, would require much more power to do all 4 at once.
  5. evezina
    Thanks!
  6. suck it up
  7. Dronason
    Switzerland
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    #8 msinger, Sep 15, 2015
  9. Newly
    BC
    Just got mine today. I thought where is the charger cord, SURPRISE, it works from the original charger and cord that came in the kit. Hmmm, no wonder they would not say anything in the specs about the wattage
  10. Dirty Bird
    Glen Burnie, MD - USA
    That is the way it is supposed to work. It charges the batteries sequentially beginning with the one with the highest charge. It does NOT charge connected packs at the same time. That would be pointless as you would just be splitting the charge current between the packs & total charge time would be the same.
  11. phantom13flyer
    Check on ebay for the blue charger . It will charge 3 batteries and the controller at the same time. It cost around 60 dollars . I'm not sure the name of it .
  12. phantom13flyer
    This one 55 bucks !!
  13. mandalay
    I vote for this one as well. Bought from this seller in China and got it in 5 days to Northern CA. It took a little less than 80 mins to fully charge 3 batteries from 16%. Amazing charger!
    Speed Charger For DJI Phantom 3 Battery and Controller
    phantom13flyer likes this.
  14. Phantom_Menace66
    Perth, Western Australia
    Just curious, does anyone read instructions anymore? Lmfao...
    HWCM likes this.
  15. HWCM
    Or item descriptions. Or owners manuals for $1200.00 flying remote control toys...
Similar Threads - DJI charging Hub Forum Date
Six DJI Phantom 4 Batteries, two Charging Hubs and two Chargers. Nearly new Classifieds Dec 23, 2017
Phantom 4 Pro High Capacity Batteries and DJI Charging Hub Phantom 4 Pro Discussion Sep 7, 2017
DJI Charging Hub Phantom 4 Pro Discussion Feb 6, 2017
DJI Intelligent Flight Battery Charging Hub Classifieds Jan 22, 2017
DJI Phantom 4 with 4 batteries, HDMI Board, Battery Charging Hub in Original Box Classifieds Sep 28, 2016
