DJI A2 Receiver Antenna
Hi Would it make sense if both antennas be mounted vertical, antenna one being vertical and the 2nd antenna be 180 degrees from that antenna, facing (tip) down. Both antenna would be vertical. Also the 2nd antenna would be separated by an inch away from the other antenna.
The other quad I have has 1 vertical and the other is 90 degrees facing the back of the quad (parallel to the Arm)
