Dji 6000 mAh battery
Hmm..I'm running a similar setup: H3-3D, fatshark 600mW, Gopro, mini iOSD. I get 17-18 minutes on my stock 5200 batteries.
6000 mAh should give us a solid 2-3 minutes more.
What are your flight times with the stock batteries?
Also how do they look in comparison to the 5200s? Same build quality? I'm sure they're heavier, do you know the weight?
I can't decide to go with those, the Limefuel Air 5400, ONBO 5400, or
Stock batteries, flying very slow, 17 minutes and weight is 368 grams.
6000 mAh, flying full throttle, 15 minutes and weight is 378 grams.
Very well manufactured. PT Assistant sees them as 6000 mAh.
wkflysaphan4
