Distance
you are in beginner mode turn it off
Reactions: dirkclod
30 feet or 30m. Beginners mode create an invisible wall of radius of 30m around home point and doesn't allow aircraft to cross it. It's a safety feature.
I found a distance fetuses I shut off but battery was low I will try again Thanks for the response
whenever you find distance fetuses, you must abort. especially when you have a low battery. next time avoid the fetuses and always start with a freshly charged baby. I mean battery.
Reactions: Milktoast
Billy you have to change that with your bird powered up to stick unless I'm mistaken and Welcome to the forum :)
As said above bird must be connected to remote when changing setting. I would make sure RTH altitude and fail safe mode is appropriate while at it.
Happy flying...
