Distance weakness
If my RC shows a weak or signal loss is it my RC or my P4? In my neighborhood the distance is super weak 148 m I believe pic attached.
The other is out on a Mesa with a long clear view and even then I only got 900m
. I know I should get better distance. Any ideas? Thanks in advance
Crap I loaded the wrong pic but even then weak.
Send dark right at this distance
Hey man, I'm totally having the same problem. My RC signal is weak and then disconnects at around 350m everytime...?? Any ideas on how to combat this??
Reactions: AVIWRAPS
Do a search for antennae orientation to make sure you have them pointed correctly.
Mark
Reactions: AVIWRAPS
You must have a lot of interference or something is wrong with the P4 or RC.
Mark
Took mine out into the country today and dropped the RC playback to 4mbs it flew easy over 1km :)
Still got that nasty gimbal tilt too though.
My P4 had a tilted gimbal after the updates and calibrations. I calibrated the IMU, gimbal and compass a second time and that took care of it. You might try that.
Mark
After I finally tested my stock RC vs my P3 modded RC I have to say, the stock is so so so very sensitive to a perfectly aligned antenna! Just a little bit off and it would lose strength, and come back to 100% with the slightest adjustment. Made it not fun to fly, and gave me more respect for the Itlite mod!
cokersean20
