Distance shorter then altitude
Discussion in 'Phantom 2 Vision + Discussion' started by Wally, Sep 8, 2014.
  1. Wally
    Amsterdam, the Netherlands
    Hi all,
    did some flying today, took off with home position locked, altitude and distance both 0.0, but later on as I was flying I noticed that my distance was 142 meter and my altitude 246 meter. I was a bit puzzled; how can this be...? I did not switch S2 to reset home position. Also, here in holland we live pretty much at sea level, should that be of influence, although I do think the altitude is measured from take off point. Had 9-10 satellites the whole flight. Did switch between GPS & ATTI mode a few times.
    Easy explanation..?
  2. tizzl10
    im a bit confused by your question..why would you think this is not possible?
  3. rrmccabe
    Ankeny, Iowa
    Are you saying those distances were when the drone was near you?
  4. Wally
    I thought distance was a line from me to the Phantom. So diagonal, and therefor always longer the the altitude. I have a feeling now that it is in fact a horizontal line to a point underneath the bird, right?
  5. rrmccabe
    Ankeny, Iowa
    Not a line. To test this in your mind go straight up about 200'. Will show your distance at just a few feet.
    Distance is horizontal. Elevation is vertical distance.
  6. BlackTracer
    Winter Park, FL USA
    Distance is not the diagonal distance from home point to the bird. It is the horizontal component as you described. And altitude is the vertical component. The diagonal length is not shown anywhere. All are measured from the home point as I think you already now.
  7. Wally
    Understood. Thanx. Sorry for the stupid question.
  8. Jstic
    The only stupid question is the one you don't ask. No need to apologize.
Similar Threads - Distance shorter altitude Forum Date
Parabolic antenna carrying a shorter distance than stock antenna? Standard/4k Discussion Sep 7, 2016
Best fstop settings for distance shots? Phantom 4 Pro Help Yesterday at 5:13 AM
Height and distance restrictions General Discussion Monday at 6:22 PM
Standard Distance and height stuck at 30m Phantom 3 Help Monday at 4:08 PM
Battery Determining Distance ? General Discussion Monday at 11:52 AM
