I went out tonight to see how far I could coax my few weeks old Phantom 4 Pro to travel. Being as my plan was to compare with my Phantom 3 Pro I set the 4's frequency to 2.4 auto. Of course same flight plan for each bird.
The Results...
The 3 Pro 9,301 feet. The 4 Pro 9,816 feet
The 3 Pro went first, and had a strong signal all the way to approx 7,000 feet after which I adjusted the antennas for strongest signal when necessary. At 9,301 ft It was pretty clear to me this was the end of the line, and not to push my luck I turned around.
The 4 Pro signal got very weak about the 5,000 foot mark and actually "disconnected" displayed on my iPad. It was too soon for me to "test" the Auto RTH so I immediately flipped the bird around to head for home. As I started the return trip I noticed both signals had dramatically gotten stronger! I decided to continue to test the bird's limit, and flew the backwards for the remainder of the outbound trip. As with the Phantom 3, I adjusted the antenna's position when the signal got weak. Flying backwards, and adjusting the antenna's I managed to go 9,816 feet. At some point along the way I had decided to stop, regardless of signal strength, at 10,000 feet. However, at 9,816 ft. the signal wasn't getting any better by manipulating the antennas, so I hit the RTH.
Observations....
The Phantom 4's signal got weaker sooner, but by flying backwards,I was able to fly another 4800 feet, to 9,816... 500 ft further than the Phantom 3. The 4's signal got weaker sooner, but the bird flew further. Hmmmm....
After pressing the Phantom 4's RTH, the transition to returning, was seeming instantaneous. Compared to the Phantom 3 which sometimes seemed like minutes went by after pressing RTH.
I never lost video with the Phantom 4. I always saw what was going on. Compared to the Phantom 3 which previously sometimes had a black screen for minutes at a time and I had no clue as to if the bird flew to earth, was flying away, or actually returning.
Questions...
Did DJI move the Phantom 4 Pro's antenna's to the front legs, or possibly a different place all together. Why else would a weak signal get stronger after the bird turned around ??
If they did move the antenna's did they move one or both frequency's ?
Next trip out I plan more testing and would like to take videos.... Will taking videos weaken the control signal or change anything. I do know to turn the videos down to 720.
Thanks for reading.. As always I am interested in your thoughts and suggestions.
Cheers,
Steve
Edit: To be clear... The Phantom 3 Antenna's were screw on non powered Omni... The Phantom 4's antenna's were factory stock.
The Results...
Observations....
Questions...
Cheers,
Steve
