- Joined
- Jul 11, 2015
- Messages
- 61
- Reaction score
- 16
- Age
- 71
This was the first flight of my new Pantom 3 crashed the last one and I also have an inspire 1 so I am very familiar with the operation and controls unless I am missing something. I am using a Samsung Note 4 and instead of the paper plane on the display showing the planes direction it is pointed in, it is showing the controllers. Made it very hard to fly back home in gps display. Never had this happen before.With the other phantom 3 or the inspire 1.
I could easily see how this could get you into trouble.
I took off facing the same direction as the plane which is normal. you fly for awhile and decide to fly back using the orange line on the gps box in the lower left hand corner which is how I normally do.
You turn the plane to follow the line back to home but in reality the paper plane is pointed in the direction you have the controller pointed. So now if you are not facing the plane and turned the controller 90 degrees, it will show on the screen that you plane is facing 90 deg from the line. So you keep turning your plane to follow the line and in reality you are making a big circle instead of coming straight home. Luckily the return to home still worked before my battery got low.
