Discovered something new with my Phantom FC40
Discussion in 'General Discussion' started by kitari, Feb 14, 2015.
  1. kitari
    Paris, TN
    I went out for a quick flight today, and after the flight I disconnected the battery, turned off the Tx, and was walking back towards the house when a nice gust of wind hit the props and made them spin really fast. All of a sudden one of my lights lit up and my phantom made a solid beep sound. so I held it upright and it stopped. Now keep in mind that my battery is disconnected and my Tx is off, so how could this happen??? I've never heard of a phantom doing this, and it was very strange. Has anybody else experienced this? I'd do it again to show you guys, but I don't wanna risk messing up my phantom.
  2. Woody
    Sounds like a capacitor discharging.
  3. kitari
    Paris, TN
    Ouch, that doesn't sound good, I hope it's ok. If something did mess up, maybe it won't be too expensive to fix.
  4. sherpa
    White Lake, Mi
    Maybe the wind turned one or more of the motors into a generator?
  5. IflyinWY
    Where the deer and the antelope play
    It was The Men In Black screwing up and turning on their monitoring device after your flight. :eek:
  6. Nidge
    Otley, West Yorkshire, UK
    The motor became a simple Dynamo.
    You can test this for yourself if you have a multimeter. Set the meter to AC and measure across any two of the three motor wires. Spin the prop by hand and you should see a reading on the multimeter. Now set the meter to measure DC voltage and place the probes across the two wires that connect the input of the ESC. Spin the prop by hand and again you should see a small voltage displayed on the meter. The ESC is working in reverse and converting the AC output of the motor into DC. If the motor spins fast enough it will produce enough current to momentarily energise the Phantom's electronics.
    Regards
    Nidge
  7. Monte55
    Raymore Missouri
    I agree. I have an electric scooter. With the power switch off, if I push scooter forward the battery status lights on handlebar will glow a bit. What's odd is that it's easy to push forward but not backward.
  8. kitari
    Paris, TN
    Wow, that's pretty cool. I learn something new every day on this forum. I'll have to try that some time. I wonder if you could use those motors and props as a mini wind powered generator like sherpa was talking about? That could be useful right?
  9. kitari
    Paris, TN
    :lol: Thanks, now I'm gonna have that song stuck in my head all day!
  10. J.James
    Upstate NY
    I attest that spinning the motors makes them work like a dynamo and generate electric. One time when a power wire broke off on the circuit board of my fc40 on night last summer. As it was plummeting back to earth I could see the lights come back on faintly as it was falling. When I got it back the next day there was also even one more file created on the flytrex after the one from the flight that ended when the power went out. It took me a bit to figure out that it had to of been from the props spining the motor being there was no way it was going to get power from the battery with one of the main leads off.
    Then when we were riding back in the car and I was trying to get some of the mud off the props by holding it out the window of the car as we were driving it back to camp. It caused the start up beeps to happen and powered up with no battery in it.
Similar Threads - Discovered something Phantom Forum Date
Phantom 3 Sport Mode discovered Pro/Adv Discussion Mar 7, 2017
Industrial River Port discovered with Phantom 3 Photos and Video May 28, 2016
I just discovered a cool feature of waypoint in DJI go Pro/Adv Discussion Feb 14, 2016
Critical Issue Discovered Pro/Adv Discussion Jan 27, 2016
Discovered A New Trick! Pro/Adv Discussion Jun 1, 2015
