Disconnected
Adelaide South Australia
My ps3 standard is showing disconnected, there is no video and the camera is hanging down and gets very hot. Can anyone please help as my new machine is grounded
Cheers
Brian
The camera and gimbal always get hot when powered on and not flying, so don't panic about that. Go into the DJI go app and tap the controller icon at the top then select link RC, once you've tapped that you'll have a 1 minute countdown to locate the button on the drone and press and hold it for 2 seconds which will sync them together. The button is located next to the landing gear strut at the rear right hand side, it's deep set but should be flashing red whilst the pairing is happening.
Hope that helps and good luck.
Thanks for your reply. I had also seen a suggestion to ininstall and reinstall the app and reformat the sd card which did the trick but I will keep your suggestion in mind in case
Cheers
Brian
Reactions: twisted1504
jrl
