Disconnected
Discussion in 'Pro/Adv Discussion' started by George M, Jul 19, 2015.
  1. George M
    Hi,
    I'll be brief
    P3P
    3rd flight at 84 meters high, 1097 meters distance, blink ImageUploadedByPhantomPilots1437321487.530621.jpg twice No Signal, I hit return Home, 2 seconds later screen is black (iPad Air) and red disconnect sign, re-launched the software, nothing!!! So I started driving to last position, took me 2 hours in the rough terrain, and nothing, went back to launch location, THE BIRD IS SITTING WAITING FOR ME
    Check the vid, results, bird hovered for 4 minutes and returned home after, I'm so glad but I'm waiting for an answer from tech to figure out why, b4 flying again ImageUploadedByPhantomPilots1437321434.262633.jpg
  2. Cacc
    Toronto, Ontario, Canada
    You lucky duck!
  3. Squirrel!
    You need to hit Vegas... :)
  4. m0j0
    You probably still had a RC signal. Upload to healthy drones we can probably figure out what happened.
    Squirrel! likes this.
  5. Mark The Droner
    One of the first drone vids I watched on youtube last summer was this similar scenario.
  6. Mike-m1911a1
    Mooresville, NC
    You will usually lose the video feed first (video goes black). In many cases though, you will still have the rc signal (green light on rc). If you lose rc signal, it will automatically return to home assuming it is set to do so in Dji go app.
    This has happened to me many times and if I still have green light on rc, can drive it towards home using the map(follow the green line in map). Once a little closer, video re-links and all is good.
Similar Threads - Disconnected Forum Date
Aircraft Disconnected but Flies Normally Phantom 4 Discussion Aug 12, 2017
LOST DJI PHANTOM 4 after App DISCONNECTED during Flight Phantom 4 Discussion Aug 8, 2017
Ribbon cable disconnected in remote Phantom 4 Help Aug 3, 2017
Aircraft Disconnected, Aircraft Battery temp n/a, gimbal disconnected Standard/4k Discussion Aug 3, 2017
Aircraft disconnected Pro/Adv Discussion Aug 3, 2017
