  1. KeithS
    Rhodes, Sydney - Australia
    Hi Guys,
    I've recently upgraded my P3p to a P4.
    I've only had a couple of flights due to not havng much time, but in the few flights I've had I've noticed a random feedback issue like the pics attached.
    The images are from a screen recorder I ran in the background to capture the issue.
    To see if it was a a range issue, I even tried it with the P4 on the ground, taking snap shots from my balcony, standing only a few metres away.
    Is this a faulty lightbridge issue do you think? I'd be interested to know if anyone else is seeing the same problem on their P4's.
    I've also experience pink / red dots when doing some night shots, I'll attach a sample of this too. I couldnt reproduce the same error whilst it was one the ground, so will try again shortly and see if it's only an issue when it's in the air.
    Any feedback will be appreciated.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    arcaine25 likes this.
  2. flyboy73
    Pine Island, SW Florida
    I can't tell you what the bars are but I believe the pink and red dots you are seeing is from lens flare. They show up when bright lights shine into your lens. They are often seen when shooting into the sun, but can also show up with other bright lights.
  3. KeithS
    Thanks Flyboy.
    Ive just done a 2nd test with a new SD card and thoroughly cleaned the lens. Pink dots seemed to have disappeared so might have been a combination of the lens flare and dirty lens.
    Lines acrosss the screen is still a worry though.
  4. Liam Doyle
    I have the same issue not the red dots but lines through the screen any ideas
  5. Brian O' Leary
    I had the same problem when using the ipad mini 1, I now use the ipad mini 2 and everything seems to be fine.
  6. Alien Warrior
    Only flown P4 twice so far.
    Happens to me as well,repeatedly on the first flight.
    Added channel hack and used channel 32, also moved the slider bar from 6M to 4M and the issue improved.
    Does not happen as often now but still occured 3 or 4 times on the second flight.
  7. Liam Doyle
    Any updates on this
  8. Phantom Juice
    I get it as well, but seems to be when image is still. Like right before takeoff. I'm using the Samsung Galaxy Tab A.
  9. Liam Doyle
    I'm using iPhone 6. And mid flight the screen pauses for a few seconds
  10. maseman88
    The pink dots are the lights from the LEDs on the arms.... lol
  11. Phantom Juice
    Pink dots? Ive never seen pink dots. I imagine it those LEDs would be a problem in low light. I wonder if these lines are an issue with the device some of us are using and not lightbridge. But then again why only when my P4 is on the ground?
  12. maseman88
    The large pink spots in the images.... You don't see those?
  13. frands1
    the green bars is the device you are using. iPad mini 1, for example, is not a "recommended" device. Also, if you are using a tablet or phone that its memory and processor are quite loaded, will see the same.
    At least, that's what I have seen using my ipad mini 1 and mini 3, also my iPhone 5s.
    Hope this helps.
  14. arcaine25
    I have the same issue, and it has happened with BOTH Brand new Samsung Galazy Tab A 9.7, and a Brand new iPad Mini 2. Both of these devices were purchased SOLELY for the use with my Phantom 3 and Phantom 4. This does not seem to occur with my Phantom 3's.
  15. Liam Doyle
    Have u had any luck with theses issues
  16. Aunt G
  17. Liam Doyle
    I'm having the very same but not as intense as this and sometimes my picture freezes
    Aunt G likes this.
  18. Cthru
    I have had the same problem I have returned the p4 waiting for my new one and I also had that stupid squeak when the camera just finished initializing
    Aunt G likes this.
  19. Northbay Drones
    I Get it as well, I also use the Tab A,,It doesn't show up on the video, but very annoying..
  20. arcaine25
    DJI isn't admitting to it yet, and there are several people on the DJI forum experiencing it as well. I think it's a lightbridge link issue if you ask me. I wish they'd address it no matter the cause
    Aunt G likes this.
Similar Threads - Digital Break Lines Forum Date
Lightning to digital AV adapter with p 4k Standard/4k Discussion Mar 31, 2017
I'm Creating Ultra Low Latency digital FPV streaming for cheap (please advise) General Discussion Feb 25, 2017
Digital Concepts 3 piece gold series filter kit outer rim question Pro/Adv Discussion Jan 20, 2017
Picture Stabilization - Digital vs. Gimbals General Discussion Jan 4, 2017
Digital video transmission options FPV (First Person View) Dec 14, 2016
