When dropping altitude, my control stick gets stuck at the bottom is this safe? Will it cut the motors
aartsf said:The bird knows that based on the altitude sensor.
Turbazz said:aartsf said:The bird knows that based on the altitude sensor.
Has an attitude sensor??
Why in groundstation it cannot work altitude out? Your home point is zero strange
If ya don't like it like that just do this .viewtopic.php?f=24&t=34545Turbazz said:When dropping altitude, my control stick gets stuck at the bottom is this safe? Will it cut the motors
1. It's not just in GroundstationTurbazz said:In the Ground Station app wherever you take off / home point It takes that ground level as zero.. basically the Phantom thinks it is flying on a flat ground.
