DEAD GIMBAL, USES FOR THE CAMERA?
The gimbal is dead, but the camera is fine! Any one know any uses that i can give to my dead gimbal and camera?
Thanx!
Is your ribbon still intact?
How is your gimbal dead?
Look up loctite (sp) and see If there is a solution.
ryanhoelzer said:
I would see if you can send it in and get it fixed..
Why is that? where you from?
I think i screwed it up, after the crash, i tried to fix it but now is jut more crazy.
lock the gimbal ( glue it up with the camera horizontal and pointing level or slightly down ) and disconnect the power to the gimbals motors. you then have a plain old vision without the tilt function. IF?? the tilt mechanism part of the gimbal is undamaged and still functional, you might be able to glue the other 2 axis and disconnect those motors but leave the tilt motor operational to turn into a plain old vision with a working tilt??
cokersean20
