DBS install
Enschede
Hello Everyone,
I received a DBS antenna because you guys suggested me to buy it!
So, i but i like to install it right now, but what are the drill size that i have to use so i fits nice..
And what about the PORTs on the DBS. What port do i have to use?
Regards,
Jacco
1/4 inch is perfect. Drill the holes in the back.
One is for the wifi, the other two grouped are for the 5.8, order doesn't matter as far as I know.
Sent from my SAMSUNG-SM-G935A using Tapatalk
So that is 6.35MM ? I think i don't have that one. Is 6.50 Okay?
Yes i will drill them in the back, do you know something about the ports?
Really? That's the exact opposite of the P2V and P2V+, and these aircrafts (P2V vs the P3S) are very similar. Could it be you're mistaken? I confess I don't have a P3S
I think the same, Because WiFi uses 2 antenna's. RX and TX.
And only 5.8 Ghz to control the bird is TX.
I misspoke. The bottom wire is for the antenna, the two above it are for wifi.
Yeah, but Port 1 Is for 5.8 Ghz? And 2 and 3 for Wifi? Does it matter which one i use?
