DBS antenna mod - worth it?
  • Thread starter Deleted member 27337
  • Start date
D
Guest
Hey guys,
Before I hack up my controller and make my P3S non-returnable, does the DBS antenna mod increase the range of the P3S by a lot?
For those of you that installed it, are you happy with it?
Does the range after install exceed what a stock P3A/P3P can do or is it still less?
Thanks so much!
Hi Tony. Look up @dirkclod as he has through a lot of trail & error & money has figured out a sweet setup for the P3S. He is getting well over 10,000' with his. I know he uses an Itelite antenna on the TX side.
full
Reactions: dirkclod
Hey guys,
Thanks so much!
Sent mine off for install. If you wait a week or so I'll
Let you know!
I actually bit the bullet today and ordered one. I will let you know my results once I get it installed.
I honestly havent flown it stock yet. I ordered this kit to get the maximum range possible from my phantom
I believe Dirkclod was quoting 6 -7000' stock.
I've pushed mine maxed at 2200-2400' but I also have a ton of interference. Hoping to get this thing over the mile mark and then possibly even adding Amps for better penetration.
Hey guys,
Thanks so much!
I hoping to get some flight time in this weekend, but since my install, all my signal bars are maxed most time. I have flown 2700ft stock before DBS mod, never had a prob, just wanted little better set up.
argues
