Dashware Issues
Discussion in 'General Discussion' started by Forts, Oct 19, 2014.
  1. Forts
    Has anyone else had issues with the video not showing when a clip is opened in Dashware? Just installed my Flytrex yesterday and made a quick flight today to give it a try. I installed the Dashware demo but cannot see any video after opening a clip. PC is running Windows 8 which from what I've read shouldn't be an issue. I've followed the suggestions in the Dashware FAQ (uninstall/reinstall Quicktime, install KLite codec pack etc etc) to no avail. I then installed it on an older Win7 pc and it works fine... but this machine struggles with HD video so I'd prefer not to use it.
    Any suggestions? Thanks!
  2. nhoover
    Los Gatos, California
    Initially I was testing it on a Windows 7 VM running on the Mac. Now I run it native in Win 8.1 and have not had a problem. Have been using since Feb 2014.
  3. Forts
    So bizarre... I still can't get this to work. Dashware says to run the Windows Media Player fixer from Microsoft... Guess what? It's not Win8 compatible. Argh!
    Are there any decent alternatives to Dashware? I played around with RaceRender a little bit and it works ok (and is even a little cheaper than Dashware), but their selection of gauges and such is mainly aimed at the automotive side of things.
  4. isky172
    Find and install the latest 64bit or 32bit (depending on your system) FFMpeg.exe files from the Interweb and put them in the Dashware folder (post-dashware install). Overwrite the original. Then relaunch Dashware and see if that fixes it. Worked on mine. (Win 8.1 w/64bit).
  5. mmn
    mmn
    Fort Lauderdale, FL USA
    Sounds to me like a video card or driver issue. Pretty sure it's nothing to do with Dashware.
  6. toolo4sno
    I am having similar issues. I have tried the KLite codec with no luck so far editing. Only a black screen/no video. That said, has anyone had success editing Dashware output files with the Microsoft Media Foundation option in 60fps. It is the output type I used for 30fps and edited in Vegas with no issues. Now it shows good for 1s then highly pixelated for the duration.
    #6 toolo4sno, May 25, 2015
  7. Xplore
    Has anyone found a fix? I have the same problem with win 10. Can't import any files. No problems importing / viewing with other programs!
    Sent from my SM-G901F using PhantomPilots mobile app
  8. Merlinthewise1
    go to
  9. Merlinthewise1
    go to healthydrones.com..upload the text file you need..after that you can download the text file as a csv file...thts the format dashware uses
  10. Dbinott
    Ottawa, Canada
  11. Mark The Droner
    I'm still on 8.1 and Dashware is still working perfectly for me. I can use Litchi or Flytrex data files - or both.
  12. Dione
    I am having the same issue with my Windows 10 desktop. However, on a whim, I downloaded Dashware to my laptop and it works on it. It is Windows 10 as well so I cannot figure out why it works there and not on my desktop.
  13. mmn
    mmn
    Because you don't yet have the Anniversary Build on your laptop?
    Mark The Droner likes this.
Similar Threads - Dashware Issues Forum Date
Dashware Create Video Error Pro/Adv Discussion Dec 16, 2017
DJI or Any Dashware Gauges ? Standard Oct 7, 2017
DashWare Installation Software Sep 6, 2017
Dashware or RaceRender Pro/Adv Discussion May 23, 2017
Has ANYONE Found a Way to use Dashware with P3 Pro Videos without having to "Pay to Play" solutions? Pro/Adv Discussion May 12, 2017
