Custom Case For MY Phantom
Discussion in 'Phantom 2 Vision Discussion' started by wildcatter, Nov 20, 2013.
  1. wildcatter
    Canton Iowa USA
  2. Pull_Up
    South Oxfordshire, UK
    Wow, Robo-Case! Where are you going to fit the coffee maker? :)
  3. wildcatter
    Canton Iowa USA
    HAHA, thats what the extra plug is for. :lol:
  4. wildcatter
    Canton Iowa USA
    I do a lot of canoeing and camping, needed a way to keep my bird in the air.
  5. Iceman
    Cambridgeshire , uk
    Looks great going to get one of them for mine just waiting for stock to come back in
  6. wildcatter
    Canton Iowa USA
  7. ShawnSmith
    Nice work, this is an excellent accessory for the zombie apocalypse! A self sustaining P2V. How long for a solar recharge on the battery?
  8. redrick
    Very nicely done!
  9. wildcatter
    Canton Iowa USA
    Thanks, I don't know how long yet, just finished it. It should charge in about 1 1/2 hours just like it does at home. the motorcycle battery should do the job. the solar is for back up. Also there is a plug for the USB :cool:
  10. wildcatter
    Canton Iowa USA
    I guess it's not for sissy's. Actually This is the same case everyone else is useing and the battery and accessories only add another 5 lbs. I open the lid to face the sun to maximize the power I get from the solar panel. It has USB ports so I can charge my AA's , wifi and smart battery. My canoe and ATV carry the load.
  11. wildcatter
    Canton Iowa USA
    Now I don't have to run home after every flight to recharge.
  12. gunslinger
    gunslinger Moderator
    Staff Member
    Least Coast...
    Great... Now I've got an extreme case of "Case Envy!!!" I just finished setting mine up and I was so proud!!!! :oops:
  13. wildcatter
    Canton Iowa USA
    Thats ok gunslinger, it's an easy upgrade.
  14. gunslinger
    Staff Member
    Least Coast...
    The wife's not gonna be a big fan of yours... :D
  15. wildcatter
    Canton Iowa USA
    hahaha, I know the feeling. :roll:
  16. wildcatter
    Canton Iowa USA
    what part about the motorcycle battery don't you get khakiss? the solar panel is to charge the m battery while I am off flying. it only takes 1 1/2 hrs to charge the phantom.
  17. Hank Reardon
    So what is the solar panel for?
  18. Driffill
    First off, I admire your creativity!
    Just a few small points, that battery would be lucky to be any more than 10aH, meaning you'll get about 3 full charges of a 11.1v 2200MaH, but it would struggle to charge the vision 5200MaH battery twice. Also, it looks to be a "flooded" lead acid motorcycle battery, meaning its likely to seep battery acid when tilted and also can produce flammable gasses while charging.
    The solar panel would be no more than 5Watts (I'm being generous there) so in full sunlight it would be pushing out about 0.4A at most. 5W/0.4A would take 25 hours (continuous sunlight) to charge a 12v 10aH battery, or 6 hours for a 2200mah battery, and 12+ hours for a 5200mah Vision battery.
    . . . Also, all those numbers are ignoring power used by the inverter and charger, and assume 100% electrical efficiency.
    I was thinking of making a similar box, I almost have, but I'd rather go without the solar (or pay big $$ for something that'll pump 3A+) and invest in a larger battery, tho that'll increase the weight a fair bit too, I did invest in a 12v charger I can run of a car (that bypass the power used by an inverter!) now once I use all my batteries (or when I'm down to my last 1 or 2) ill put the rest on charge in a vehicle and I'm able to continue flying (with someone else watching the charger) this almost allows me to fly around most of the day, currently with only 4 "flight" batteries.
    But still, nice work ;)
  19. wildcatter
    Canton Iowa USA
    your right about the battery. I mounted the battery so that the vent tube is on the top side when I am carrying the case. Also I vented the battery. I am not sure what the solar panel puts out. I bought it awhile back, it is specifically for charging 12 batteries. Something I was useing to charge tracktors, lawn mowers. This was all just a test with parts I had laying around the shop. I plan to replace the battery with a gell cell, maintenance-free battery. I did put the dual power plug in so I can plug into the powerport on my ATV as well. All in all what it comes down to is I can stay out all day now and be flying. Good luck with your build and let us know what you come up with. thanks
Similar Threads - Custom Case Phantom Forum Date
Custom Phantom 3 case... Pro/Adv Discussion Jun 16, 2015
A custom case for the Phantom 2? Phantom 2 Discussion Jun 19, 2014
Custom Phantom 2 Case for travel? General Discussion Mar 11, 2014
Custom carry case Standard/4k Discussion Jun 10, 2016
