Cross Restricted Zones
Discussion in 'Phantom 2 Vision + Discussion' started by dubiousp, Feb 1, 2015.
  1. dubiousp
    I took the plunge a couple of weeks ago and purchased the + been quite nicely flying around and using the RTH function etc.
    Using the APP Ive tried to program way points but on each occasion it gives an error message of unable to cross restricted zones. Having looked at the restrictions I do not seem to be in them,
    Anybody have any ideas
  2. Larry L
    Copperas Cove, Texas
    No, have not seen that error. I normally do not use ground station but if you try to set a way point outside of the max distance, it will not allow you to proceed. Could that be your restriction?
  3. dubiousp
    I do not think its a distance restriction as Im only setting no more than 100 ms as still quite a novice
  4. dubiousp
    Im 3 miles from the nearest airport which is in cat b
  5. dptcalvin
    Are you on 3.10? I believe it's a 5 mile radius around airports that you cannot fly in.
  6. dubiousp
    yes 3.10 is that for both cat a and b airports
Similar Threads - Cross Restricted Zones Forum Date
Severn Beach and Second Severn crossing Standard Jan 15, 2018
Litchi cross reference Control (Go, Litchi, etc..) Dec 26, 2017
Just crossed 6,000 Subscribers on YouTube: THANK YOU! Photos and Video Dec 6, 2017
CRAZY FOOTAGE THAT I CAME ACROSS ~ Enjoy! General Discussion Nov 25, 2017
Had strange white lines come across my camera view Phantom 4 Pro Help Nov 23, 2017
