crooked horizon for 12 sekonds
Discussion in 'Phantom 2 Vision + Discussion' started by pegasusjan, Nov 30, 2014.
  1. pegasusjan
    During flight after some minutes the camera is not level. See : https://www.youtube.com/watch?v=g9_rfvBVyzY
    The last 8 minutes from this flight everthing oke ( level camera oke)
    What could be the problem ?? (must I worry)
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Your video is private.
  3. pegasusjan
    Sorry, now it is public
  4. CaptainZero711
    Hey hey, I have also had this issue on a few flights. Any ideas why this happens and how to prevent it? Thanks CZ
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    If you haven't done so already, try installing all available updates via the DJI Phantom 2 Vision Assistant.
  6. pegasusjan
    All (last) updates are installed.
  7. aartsf
    After updating of especially fw, recallibration is often to be advised. Did you do that?
    Regards. FA
  8. pegasusjan
    What do you meen with " especially fw"
  9. aartsf
    Fireware upgrades do require more often recallibration than simple software upgrades. That is because Fw upgrades are more likely to interfere with the flight/ control characteristics and sw upgrades not.
  10. pegasusjan
    I did severall recallibrations (transmitter, IMU) and for the flight a compas calibration
  11. 4wd
    4wd
    North York Moors
    I have seen mine do it briefly during a flight - but it was normal again next time.
    I suspected some debris maybe chopped up insect bits (?)causing some slight unbalance or disturbance.
  12. aartsf
    In that case I am out of rational options. Maybe/hopehully it was a one time only random event due to dirt in the gimbal or something like that. Keep us posted.
    Wish you all the luck.
Similar Threads - crooked horizon sekonds Forum Date
Inconsistent Crooked Horizon - P3A Pro/Adv Discussion Feb 21, 2016
Phantom 3 Crooked Horizon - What is Acceptable / Normal Pro/Adv Discussion Dec 15, 2015
Standard Gimbal Crooked after Crash Phantom 3 Help Jul 23, 2017
Phantom 4 gimbal crooked Phantom 4 Help Jun 8, 2017
Crooked Gimbal/used gimbal Phantom 4 Help Jan 23, 2017
