Standard Crashed my p3s won't power on
Discussion in 'Phantom 3 Help' started by Kmurphy1990, Apr 11, 2016.
  1. Kmurphy1990
    Crashed my p3s yesterday in strong winds.
    Battery fell out on impact with wall but was a very low speed crash about 4 feet above ground . Broke one prop and when I tried to power up the drone again it would not power up . Any ideas guys am a newbie to the forum
    Cheers Kyle
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    What happens when you press the button on the battery? Have you tried a different battery?
  3. Kmurphy1990
    Uploaded video not sure if use can see it
    Was trying to up load video when the battery is removed I press the button once and 3 light go green one flashes for around 2 seconds then all go off
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Are you able to turn on the battery when it's not in your Phantom?
  5. Kmurphy1990
    Just in the process of uploading videos . Nearly sure the battery powers up on its own
  6. Kmurphy1990
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Looks good. How about when you double press and hold?
  8. Kmurphy1990
    They all light up one after the other then the furthest light from the button stays on for few seconds
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It sounds like you're checking the battery life. I'd like you to try turning on the battery -- like this:
  10. Kmurphy1990
    Will I Do this with the battery in the drone
  11. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I thought you were confirming that it does not power on when the battery is in the drone. That's why I was asking if the battery powered on when outside of the drone. It should.
  12. Kmurphy1990
    Still the same with it in the drone after I let go after holding one LED flashes for a second or so then off
  13. msinger
    Approved Vendor
    Harrisburg, PA (US)
    If you're sure you're powering on the battery properly, then I'm going to conclude it must be damaged. You should replace it.
  14. Kmurphy1990
    image.png This is what I get when I try power on the battery when it's out and it's the same when in the drone
  15. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Can you post a video? It's hard to understand what you're showing in the above photos.
  16. Kmurphy1990
    Trying to upload video of my phone and it's not working al try it on the laptop now . Thanks
  17. Kmurphy1990
    [​IMG]
  18. Kmurphy1990
    [​IMG]
  19. mdowney58
    Mountain City, TN
    It sounds from his description that the battery is powering on, and the lowest (<25%) LED is lit
    Sent from my SM-N910V using Tapatalk
  20. Kmurphy1990
    Any idea what problem could be
Similar Threads - Crashed p3s won't Forum Date
Standard Crashed P3S During RTH Phantom 3 Help Jun 26, 2017
Crashed P3S Standard/4k Discussion May 16, 2017
Crashed P3S Standard/4k Discussion Apr 4, 2017
Crashed my P3s..... Standard/4k Discussion Feb 6, 2017
Standard Crashed my P3S Phantom 3 Help Jan 22, 2017
