Professional Crashed during testing. Gimbal parts questions
Discussion in 'Phantom 3 Help' started by Air Ontario, Mar 4, 2016.
  1. Air Ontario
    U.S./ Canada
    Had a weird crash today into trees(trunks). Bird took right angle to flight path, sped up and Tee boned a tree trunk.
    It appeared the bird stopped and hovered(it quit moving along the current path). I waited a few seconds 10-15 and tried to move the bird along the previous path and it shot at a right angle to the path and into trees.
    I suspect it stopped(unknown reason) while videoing at 9 o'clock and traveling towards 12 o'clock. I tried to increase the speed (with stick and inside program with slider) to see if it would move along it's 12 o'clock path but saw no movement nor any screen indication.
    I toggled to PGPS and tried to ascend and saw no movement. Sometime after that it apparently sped up and went towards 9 o'clock(where it was videoing) and hit a tree trunk.
    I have from the square gimbal mount plate downwards off(2 multi-wire cables unplugged) and the pins and vibration dampers, camera, etc removed.
    I need a parts dealer recommendation(nothing in classifieds) and is it better to replace it all(from the sq. flange down or just the ribbon and gimbal arms. The yaw gimbal arm seems out of plumb, unless it comes that way and the ring on the pitch gimbal is broken in two.
    The bird flies super with the cam/gimbals off. lol
    #1 Air Ontario, Mar 4, 2016
  2. berlib
    Aix en Provence, France
Similar Threads - Crashed during testing Forum Date
GO APP Crashed during POI and low battery Control (Go, Litchi, etc..) Jul 23, 2017
Standard Crashed P3S During RTH Phantom 3 Help Jun 26, 2017
Litchi app crashed during waypoints mission Standard Jun 25, 2017
Litchi app crashed during end of way points. RTH initiated. How to cancel the RTH using RC? Standard Oct 8, 2016
Airnest crashed twice during plan flight Phantom 4 Discussion Jun 12, 2016
