CRASHED BATTERIE
Yesterday i crashed my dji vision 2 +
The batterie jumped away after the crash. And it smashed agains the floor.
1. How do i repair the batterie?
If it is not possible...
2. How do i dispose? can i have it in the house? Is there any risk it burns itself?
It is almost new!
The quadcopter is in bad condition, but about that i will tell you next time.
Must have been a really hard crash.
I suspect that battery is toast.
If you can manage to get it working again, it will classify in the category " unreliable ".
Maybe it is just me, but I would be more concerned in the condition of the quad copter. If the battery is in that bad a shape, it might be interesting to see some pics of the bird itself. Sorry about your crash.
I will post an extensive review about the crash and my doubts. My mother language is spanish, i can only tell you before how it can be evaluated:
Pequeña evaluaciòn de daños:
1 baterìa inutilizada
1 gimbal inutilizado
1 cámara desconectada
1 helice destrozada
En el mismo cuerpo:
Al intentar poner las hèlices:
1 helice enrosca bien y gira bien
1 helice enrosca bien pero al girar raspa contra el brazo
(brazo dañado y doblado)
1 helice no enrosca (punto negro) (hay que forzarla un poco para enroscar)
1 helice no enrosa (punto gris) (hay que forzarla un poco para
enroscar)
Al colocar la batería:
Funciona la baterìa puesta
Al encender la baterìa en el phantom pero sin helices:
TODOS los motores ENCIENDEN
TODAS LAS LUCES FUNCIONAN
Damage Assessment:
One battery destroyed
1 gimbal destroyed
1 camera disconected
One propeller destroyed
In the same body:
When trying to put the propellers:
One propeller twists and turns rather well
One propeller when turning scraps against the arm.
(damaged and bent arm)
1 propeller cant be screwed (black dot) (you have to force it a little to tighten)
1 propeller cant be screwed (gray dot) (you have to force it a little to
screw)
By placing the battery ( a new one):
The battery starts and works
When you turn the battery on the phantom but helices:
ALL engines work
ALL LIGHTS WORK
Stile2112 said:
Wow, I would not store that battery in your house. To many horror stories of damage Lipo's catching fire or exploding.
No Way!
Lipos have a bad rep. and while I may not practice some of the cautions others take, a damaged one that can never be reused has no place in my house.
