Crashed and Power GND popped
Discussion in 'Phantom 1 Help' started by xavyermorgan, Aug 29, 2013.
  1. xavyermorgan
    So! I crashed finally. It's sure sturdy. However, there is an adhesive on the motherboard. When the battery compartment popped out during the crash, the ground wire came undone. Power won't come up. When I place the ground wire back in contact and a battery is connected, voila! So my question (as I am not an electronics wizard yet)... what adhesive do I use to put this thing back on? It's such an EZ fix. I just need to know the material to use.
      File size:
      21.4 KB
      203
  2. Skylane765
    You will just solder the wire back or if you pulled the copper trace, epoxy.
    Or just solder to a different place on the board that is ground, there are many of them.
  3. SCADAMON
    Did it pull the pad off the board? From the picture it looks like that is what happened. You will need to "SOLDER" it back to another "Ground" point on the board.
  4. xavyermorgan
    I re-soldered. It worked. About to reassemble. Wish me luck! The power now connects and I get the little tune.
  5. xavyermorgan
    Back in the air!!!
Similar Threads - Crashed Power GND Forum Date
Standard Crashed my p3s won't power on Phantom 3 Help Apr 11, 2016
Crashed p3p...power died moments after takeoff Pro/Adv Discussion Dec 9, 2015
Crashed and now Phantom 2 won't power up... Phantom 2 Help Sep 27, 2014
P2 with H3-3D Gimbal Crashed and died - Power loss Zenmuse H3-3D/H4-3D GoPro Gimbal May 15, 2014
Crashed into tree P2v powers up but props won't start HELP Phantom 2 Vision Discussion Dec 21, 2013
