Crash!!!! ????? What went wrong
Discussion in 'Pro/Adv Discussion' started by Gunner200, Dec 23, 2015.
  1. Gunner200
    Just took my P3p out to show a friend how it works. Full battery flew around just fine then I flew it 100 meters out and pushed return to home on app to show him that. App said it was acceding I noticed drone was acting odd turning side to side etc. I then canceled return to home and as soon as I manually lowered drone it fell out of the sky.
    Conditions were foggy and 34 Fahrenheit
    I will try to add flight log
  2. Gunner200
    How do I load flight log onto forum?
  3. Mark The Droner
    Can you tell us more about the battery? When did you last use it and when did you last charge it?
  4. SanCap
    South West Florida
    Foggy and 34 degrees F, maybe it iced up?
  5. flyNfrank
    Indy, USA
    A .txt or .zip file can be added the same as uploading a image. Look to the right of the "Post Reply" button.
  6. Gunner200
    I purchased drone a few weeks ago and had drones plus install latest firmware and check out all updates at the store made I purchased 3 batteries and charge each battery after every flight regardless of how long I fly it. This battery was charged 24-48 hours before this flight
  7. alokbhargava
    San Francisco, CA
    We will know more after seeing logs.
  8. Gunner200
    I am trying to figure out how to send flight log. My phone says I can send as a text message or email but not sure how to add it to forum? Forum only gives me an option for pictures
  9. bighi
    Gibraltar/Austria/Italy
    Hey Gunner, just below the box where you type the message, there are three bubbles. One says post reply, the next says upload a file, the third says more options. Click on that middle one, upload a file.
  10. Gunner200
  11. Gunner200
    Got it. Take a look at the flight. Soon after return to home is engaged it loses control
  12. Gunner200
    Mine has no bubbles it has a plus sign on left and send on right
    Modern Vision likes this.
  13. Zerone
    S.Wales, UK
  14. Gunner200
    Mm mm will try that
  15. Gunner200
  16. Gunner200
    here is the actual flight file.
  17. Erroll
    South Africa
    Based on the post below, I am removing my post. It does appear that the battery anomaly is as a result of the crash, not the cause.
    #17 Erroll, Dec 24, 2015
  18. 0000edgar0000
    Your compass started going crazy at 5:55 then im assuming it spun out of control. You never lost gps though. Battery temp spiked at crash landing. Were you also fighting wind?
    Compass issues is why i returned mine. Mine was swithching to ATTI mid flight.
    Wondering if fog and wind made yours go out of control. Dont know the normal battery temp but you were in the 100F range at the end. Looking at my own logs, Im only at 80F at 6mins (35F outside). Which makes me wonder if fighting wind made your battery overheat.
    #18 0000edgar0000, Dec 24, 2015
  19. Gunner200
    Wind was light? Not really noticeable. It was foggy and cold? I have 10 flights this week under similar conditions. I am sending back to DJI to get it checked out
  20. 0000edgar0000
    Do you have the old or new motors on it?
    #20 0000edgar0000, Dec 24, 2015
Similar Threads - Crash went wrong Forum Date
Drone crashed! Help me determine what went wrong... General Discussion Jun 1, 2017
P4 went into uncontrollable pirouettes, crashing Phantom 4 Discussion Jun 23, 2017
New P3 Standard, propeller went astray and crashed Standard/4k Discussion Mar 25, 2017
HELP! P3 Professional went out of control and crashed. Pro/Adv Discussion Jun 19, 2016
Firmware update crash. Went to upgrade and getting this message repeatedly. Help! Pro/Adv Discussion Apr 8, 2016
