- Joined
- Jan 21, 2014
- Messages
- 15
- Reaction score
- 0
Well, today my worst Phantom-nightmare came to life: my phantom just fell out of the air from about 65 meters height
Was just flying around at about 100m altitude and all of a sudden IOC started acting stange again (happened before). Each time Course Lock would just disengage. Happened to me a few times before, but this time it was happening every 10 seconds or so. So I decided to descend and land the Phantom. Then all of a sudden, I saw the Phantom tumbling from the air, seems like the motors just stopped in mid air. When it was about half way to the ground, all of a sudden the motors started spinning again, and it looked like the Phantom was recovering, but unfortunately the motors stopped again. Only thing I could do was watch my Phantom smashing on the ground. On my iPhone, the screen showed "connection lost" and an altitude of 65 meters. (so apparently it was a power failure, because this seems to indicate that power to the camera was lost at an altitude of 65m. I had set my camera to take a picture every 5 seconds, but the last photo recorded also was high up in the air, so I guess it also stopped at 65 meters).
Damage seems to be limited: as far as I can see, only the landing gear and the camera mounting bracket are broken. So I will order replacement parts and see if I can get my Phantom airborne again.
Will also check and double check the power system of the Phantom. I am beginning to suspect that there might be a lose contact or something like that (that would explain IOC disengaging I guess).
So I think this is also a warning for others: if you experience IOC repeatedly disengaging for no apparent reason, get down ASAP!
Keep you posted
Rob
Keep you posted
Rob
