Crash rebuild
Discussion in 'Phantom 2 Discussion' started by markab, Apr 5, 2014.
  1. markab
    Just finished rebuilding my P2 after a stupid crash, seeing as I had to replace the shell I decided to run the cables for iOSD, flytrex and gimbal a different way from the norm to try and get a tidier finish.
    iOSD is mounted on the back of the gimbal with tape and then the fpv hub is mounted to the iOSD...
    [​IMG]
    The flytrex is then placed right above it out of the way...
    [​IMG]
    Finally I cut one of the cooling fins out of the cooling vent on the canbus side and ran the iOSD can bus, zenmuse and flytrex cables through it, taking out one fin with a sharp knife is just big enough to fit the canbus connector through and looks a lot tidier than connecting on the leg...
    [​IMG]
    The canbus port has been moved inside the shell to tidy things up further. Now I have a good amount of space left to mount the avl58.
  2. OI Photography
    Clarksville, TN
    Very nice!!
    I didn't realize the iOSD mini and hub could be mounted so neatly together on the back of the gimbal...I'm surprised I haven't seen that before. Even with all the cables to the hub you did a great job of keeping them tidy.
  3. Fink
    Orlando, FL
    Looks great! Coming from somebody with extreme OCD when it comes to things like this, I can appreciate the time it took to do this!
    Fink[​IMG]
  4. markab
    And finally with the AVL58 mounted on a 3D printed platform...
    [​IMG]
    [​IMG]
    [​IMG]
  5. Boozshey
    Looks cool.
    What is the board in the middle with the mSD card for?
    Nevermind, just looked up flytrex... that's pretty cool!
Similar Threads - Crash rebuild Forum Date
P3S Rebuild and Paint job after crash. Standard Jan 26, 2017
Crash rebuild Standard Oct 21, 2016
Need Your Advice: Crashed P3A, Rebuild? Or Purchase New? Pro/Adv Discussion Dec 14, 2015
Issues on rebuilding after crash Phantom 2 Vision + Help Nov 21, 2015
Post crash/post rebuild P2V+ LED Sequence Problem Phantom 2 Vision + Discussion Sep 18, 2014
