Crash now rebuild...
Discussion in 'General Discussion' started by davejschumaker, Jan 21, 2014.
  1. davejschumaker
    So was flying this weekend and ended up crashing when a gust blew my phantom (v1.1.1) in to a tree then it fell on to a rock. As one of the arms is cracked and bent badly enough to have the blade hit it I'm left with a choice. Do I get a new Phantom shell to transplant everything or do I get something like a flame wheel body to move everything to? I like the look of the Team Black Sheep frame, but I think I'll want to use that for a ground up build. Also if I go with a Flame Wheel, any benefit to going to 6 rotors?
  2. 750r
    Pa, USA
    Around $50 for a body I would replace it that will give you some hands on for when you build the bird you want . I know spring I will be starting a ground up build .
    GL
  3. OI Photography
    Clarksville, TN
    1. You can lift more
    2. Your bank account will be protected from growing too large :lol:
  4. davejschumaker
    750r - Any good places to buy a new phantom body?
    OI - So if I don't plan on lifting more, would that equate over to longer flight time with what I currently lift? Which right now is just a gopro. I would like to build in FPV at some point, but don't see me doing much more than that.
  5. Gizmo3000
    Sherman Oaks, CA
    the only thing you can really transfer to another frames is the NAZA and the motors, perhaps the ESC's if you can figure a way to rig them up, but you'd need a new GPS puck.
    I just recommend getting a new Phantom shell, selling the Phantom and using the money to build a bigger Quad or hex.
  6. OI Photography
    Clarksville, TN
    Ditto.
    Dave, if you don't need to lift more than that I wouldn't bother with a 550, but moving to a 450 at least would give you the ability to use larger batts than what will fit in the Phantom's shell. You might also want to consider a TBS Discovery Pro or similar quad platform in that class, there's several that are rather nimble and efficient and purpose-designed for gopro's and FPV.
  7. 750r
    Pa, USA
Similar Threads - Crash rebuild Forum Date
P3S Rebuild and Paint job after crash. Standard/4k Discussion Jan 26, 2017
Crash rebuild Standard/4k Discussion Oct 21, 2016
Need Your Advice: Crashed P3A, Rebuild? Or Purchase New? Pro/Adv Discussion Dec 14, 2015
Issues on rebuilding after crash Phantom 2 Vision + Help Nov 21, 2015
Post crash/post rebuild P2V+ LED Sequence Problem Phantom 2 Vision + Discussion Sep 18, 2014
