Ok so heres the story...
Opened up my Phantom 2 Vision yesterday, thrilled and excited. After charging everything I plugged the Phantom into the Assistant Software and made sure everything was updated, same with the remote. Flew it for the first time today. Everything was working great and I was having a ball.
And then... I was asked to give a demonstration to some fascinated neighbors, so I did. However, a group quickly formed and in the midst of things I became slightly distracted and crashed the Phantom into a tree. AGH. After a couple seconds it wiggled loose and fell to the ground.
Only visual damage was a couple props broke, camera was detached, and the battery popped out. I easily swapped out the props, reattached the camera, and popped back in the battery. But now I have continuous blinking yellow lights, which I guess means "remote controller signal loss". The Phantom powers on normally but it will not respond to the remote control.
What I've Done:
Opened up the Phantom to make sure the antennas were still attached: Everything appeared normal.
Plugged in the Phantom to see if it would connect to the Assistant Software: It did and everything appeared fine.
I'm a total newb.
What do I do?
Thanks for any help!
What I've Done:
I'm a total newb.
What do I do?
