dirkclod said:Tried it out today on range and still have some tweaking to-do as all I could get was 6576' but will work with that as I know I can get more !!
Wow..you turned your phantom into a beast! ! Was that flight with the stock controller? ?dirkclod said:After I messed up my shell I decided to just make mine a P2V/V3 So here it is .
I sent it to UAVDirect and Eric there we came up with what I wanted .
New Shell
New V3 Compass
New V3 GPS
2312 Motor's and V2.1 ESC's
All new cables and just had him check everything out.
Also added a new V3 TX and the FPVLR Bird Side Antenna's
It is at least 25% quieter than before and a lot more responsive ! Just got through doing the mod on TX for my antenna's so I haven't flew with the scroll wheel yet and need to do the other mods to it but just gonna fly for awhile
I gota Thank Eric at UAV for doing the bird and HappyFlyer for the help with my Antenna set up and other things as well . And Slinger... Thanks for the part bro !!! Here's some pic's .
Me just happier than hell
Do you mind being more specific ? Are you talking about the smaller antennas?FPVLR said:looks like antenna placement needs tweaking, the side antennas need to point out the side more.
Tony.
What do you have mounted on the back of your phantom? ?dirkclod said:It was the original but had the stage 3 antennas . Now I have the V3 TX and have moved all over to it .
Here's what I did..I got a piece of plastic burnt three holes in it and super glued a piece of industrial strength velcro on it and mounted it to the leg cadi corner from the compass ..here's the tricky part..on the tk102 you need to scruff up the back where you put the velcro. .make sure to super glue it to the tracker. . Attach it to your phantom. .there's no way it will fall off,but you can put an additional zip tie from the tracker around the leg..crash1sttime said:Never thought to put my TK102 tracker in that position, apart from the 2 cable ties how are you keeping it fixed to the leg ? and are you able to get the battery in and out with ease, as I remove my battery when im not using it.
dirkclod said:Edit / Added a different picture with some more color to it and took care of that # issue Cyclone
dirkclod said:Ok now we OT :shock:
